By marcelstoer
#78246 It's a real pleasure to announce the general availability of the Lua Flash Store (LFS) in the NodeMCU firmware! This is a decisive improvement for anyone writing larger Lua applications with NodeMCU.
LFS allows Lua code and its associated constant data to be executed directly out of flash-memory; just as the firmware itself is executed. This now enables NodeMCU developers to create Lua applications with up to 256Kb Lua code and read-only constants executing out of flash. All of the RAM is available for read-write data!
A LFS whitepaper was added to the documentation; a very interesting read.
LFS is also supported by the NodeMCU cloud builder and the Docker build image.
Pending PR https://github.com/nodemcu/nodemcu-firmware/pull/2487 will offer a much better Getting Started documentation.
