Luckily, there is code to do this here:
https://github.com/moononournation/nodemcu-webide/blob/master/bin/httpserver-websocket.lua
(courtesy of @creationix and/or @moononournation)
This works as described and I am able to send a message from the client to the NodeMCU server, which then responds based on the received message. Great.
My questions are:
1: How can I send messages to the client without it having to be sent as a response to a client request (standalone sending of data)? When I try to call socket.send() socket is not found as a variable, which I understand, but cannot work out how to do it!
2: Why does the decode() function output the extra variable? What is this for? I'm assuming it will be for packet overflow, but I can never seem to make it return anything, regardless of my message length.
3: In the listen method, why has the author added a queuing system? is this essential or for applications that perhaps may receive multiple simultaneous messages? Ideally, I'd like to remove it.
I have simplified the code as below:
(excluding the decode() and encode() functions - please see the link above for the full script)
net.createServer(net.TCP):listen(80, function(conn)
local buffer = false
local socket = {}
local queue = {}
local waiting = false
local function onSend()
if queue[1] then
local data = table.remove(queue, 1)
return conn:send(data, onSend)
waiting = false
function socket.send(...)
local data = encode(...)
if not waiting then
waiting = true
queue[#queue + 1] = data
conn:on("receive", function(_, chunk)
if buffer then
buffer = buffer .. chunk
while true do
local extra, payload, opcode = decode(buffer)
if opcode==8 then
print("Websocket client disconnected")
--print(type(extra), payload, opcode)
if not extra then return end
buffer = extra
socket.onmessage(payload, opcode)
local _, e, method = string.find(chunk, "([A-Z]+) /[^\r]* HTTP/%d%.%d\r\n")
local key, name, value
for name, value in string.gmatch(chunk, "([^ ]+): *([^\r]+)\r\n") do
if string.lower(name) == "sec-websocket-key" then
key = value
break
if method == "GET" and key then
acceptkey=crypto.toBase64(crypto.hash("sha1", key.."258EAFA5-E914-47DA-95CA-C5AB0DC85B11"))
conn:send(
"HTTP/1.1 101 Switching Protocols\r\n"..
"Upgrade: websocket\r\nConnection: Upgrade\r\n"..
"Sec-WebSocket-Accept: "..acceptkey.."\r\n\r\n",
function ()
print("New websocket client connected")
function socket.onmessage(payload,opcode)
socket.send("GOT YOUR DATA", 1)
print("PAYLOAD = "..payload)
--print("OPCODE = "..opcode)
end)
buffer = ""
conn:send(
"HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\nContent-Length: 12\r\n\r\nHello World!",
conn.close)
end)
end)Any help would be much appreciated! Thanks
