Tried 8 and 9 node builds from frightanic.com float with/without OW
issue 1> using older ESP8266 Flash Downloader appears to flash ok , but unit appears to hang in reset,reset,rest etc
issue 2> using NodeMCU Firmware Programer Flashes ok
loadinga working[0.9.6] lua pgm and dofile("xx.lua")
wifi gets an IP address xx.xx.xx.34
when connect to xx.xx.xx.34 connection appears to succeed, HOWEVER, nothing displayed.
wifi.sta.config(SSID,PASSWORD)
print("wifi is loading")
print("please wait.")
print("please wait..")
print("loading" ..=wifi.sta.getip().." wifi info sent")Then you can see if you are getting your IP or not... I had trouble trying to print it immediately after station it would just say 192. or 192.garbadgehere Its like you need a delay before you can print.
If this is what you are trying to do that is maybe I misunderstand a bit if I do just disregaurd this posting.
Where I buy my ESP8266 boards from... (Banggood)
sdk 1.4.0 only displays the 1st line......my ver of 1.4 has an issue...
