Heap: where does it go?
PostPosted: Sun Dec 13, 2015 4:39 pm
by Trickuncle
Heap, oh heap, wherefore art thou heap? Why dost thou flee so hastily?
My code below does pretty much what I want - open in a browser and it displays a slider control, sends it's value when it changes to the ESP8266 module which parses out the value, applies it to the pwm function of the red led and it's complement to the blue led. Slide the slider, see the rate of blinking speed up or slow down.
All good until the heap disappears and the module reboots. I sprinkled some 'show heap' print statements through the code with index numbers to make it easier to tell which printed value came from which part of the code.
Each time the slider is changed, four heap values are printed out. Here's a view of what the first few heap values look like:
=node.heap()
25464
1= 23560
2= 23880
3= 23880
4= 22288
1= 23216
2= 22832
3= 22880
4= 21336
1= 22840
2= 22488
3= 22536
4= 20984
1= 22192
2= 21792
3= 21800
4= 20248
1= 22632
2= 22232
3= 22304
4= 20752
1= 22304
2= 21896
3= 21904
4= 20376
1= 22264
2= 21920
3= 21968
4= 20416
1= 21912
2= 21544
3= 21456
4= 19824
A little up then a big jump down, relentlessly, heading for the PANIC- out of memory error and reboot.
If anyone has ideas on how to debug this or suggestions as what is causing it, I would love to hear from you! Thanks!
Code: Select allwifi.setmode(wifi.STATION)
wifi.sta.config("xxx","yyy")
print(wifi.sta.getip())
redled = 3
blueled = 4
gpio.mode(redled, gpio.OUTPUT)
gpio.mode(blueled, gpio.OUTPUT)
srv=net.createServer(net.TCP,3600)
srv:listen(80,function(conn)
    conn:on("receive", function(client,request)
print("1",node.heap())
        local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
        if(method == nil)then
            _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
        end
        local _GET = {}
        if (vars ~= nil)then
            for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
                _GET[k] = v
            end
        end
print("2",node.heap())
        pwm.setup(redled,1000,511)
        pwm.setup(blueled,1000,511)
        tmpwm = 50
        ramp = 0
        pwmout = 100
        if(_GET.somevar) then
            pwm.start(redled)
            xxx = (_GET.somevar);
            tmpwm = tonumber(xxx)
            if(tmpwm>1023) then
                tmpwm = 1023
            end
        end
      function motordrive()
            ramp = ramp + 80
         if (ramp > tmpwm) then
            ramp = 0
            if rampdir  then
                pwmout = pwmout + 10
               if pwmout > 1023 then
                  pwmout = 1023
                  rampdir = false
               end
            else
                pwmout = pwmout - 10
               if pwmout < 10 then
                  pwmout = 5
                  rampdir = true
               end
            end
         end
      pwm.setduty(redled,pwmout)
        pwm.setduty(blueled,1024 - pwmout)
      end
      tmr.alarm(0, 1, 1, motordrive)
print("3",node.heap())
      conn:send('<!DOCTYPE html>')
      conn:send('<html>')
        conn:send('<body bgcolor="Turquoise">')
        conn:send('<h1><center>===> X*Y*Z*T <===</center></h1>')
        conn:send('<h1 style="font-size:300%;">')
        conn:send('<center><p id="demo" /p></center>')
        conn:send('<center><font color=red><b>Faster</b></font>')
        conn:send('<input style="width:550px; height:50px" type="range"  name="cmd" id="cmd" value="" min=1 max=1023 step=1 onchange="myFunction()"/>')
        conn:send('<font color=red><b>Slower</b></font></center></form></h1>')
        conn:send('<script>')
        conn:send('function myFunction() {')
        conn:send('    var x = document.getElementById("cmd").value;')
        conn:send('    document.getElementById("demo").innerHTML =  x ;')
        conn:send('    var uri = "\?somevar=" + x;')
      conn:send('      var xhttp = new XMLHttpRequest();')
        conn:send('    xhttp.open("GET", uri, true);')
      conn:send('    xhttp.send();')
      conn:send(' }</script>')
       conn:send('</body>')
       conn:send('</html>')
        client:close();
        collectgarbage();
print("4",node.heap())
    end)
end)
Re: Heap: where does it go?
PostPosted: Tue Dec 15, 2015 8:12 pm
by Trickuncle
Update - still no idea of what's going on (as usual!) but commenting out all HTML and javascript produces working Lua code that runs my pwm routines and does not lose heap space so I'm beginning to narrow down the investigation.
PostPosted: Wed Dec 16, 2015 1:50 pm
by Trickuncle
Looks like I found the solution to my heap loss problem. I was sending HTML and javascript from the server based on sample code I found on the net and closing the connection improperly. My code simply had this line at the bottom:
Code: Select allconn:close()
Apparently, the connection must be queried looking for the 'sent' event and only then close.
Code: Select allconn:on("sent",function(conn) conn:close() end)
conn = nil
I had posted this on a different forum about a related topic but wanted to put it here for anyone still as confused as I was(am).
