This is the content of init.lua:
wifi.setmode(wifi.STATION)
wifi.sta.config("Gandalf","simonecleomartina")
uart.setup(0,9600,8,0,1)
print(wifi.sta.getip())
print ("uart.setup(0,9600,8,0,1) finished")
print ("waiting for serial data....")
tempst = "N.D.";
srv=net.createServer(net.TCP)
srv:listen(46,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
buf = buf.."<h1> ESP8266 Web Server</h1>";
buf = buf.."<p>Temperatura "..tempst;
local _on,_off = "",""
if(_GET.pin == "Cancello")then
print("1");
elseif(_GET.pin == "Garage")then
print("2");
client:send(buf);
client:close();
collectgarbage();
end)
end)
function temp(value,decimal)
print("Temperatura("..value.."."..decimal..") ricevuta")
tempst = value.."."..decimal;
This is the code that i use in C# for downloading the web page content:
int timeout = 5000;
SetAllowUnsafeHeaderParsing20();
HttpWebRequest myHttpWebRequest1 = (HttpWebRequest)WebRequest.Create(action);
myHttpWebRequest1.KeepAlive = false;
myHttpWebRequest1.ServicePoint.Expect100Continue = false;
myHttpWebRequest1.Timeout = timeout;
myHttpWebRequest1.ReadWriteTimeout = timeout;
myHttpWebRequest1.ServicePoint.MaxIdleTime = timeout;
myHttpWebRequest1.ServicePoint.ConnectionLeaseTimeout = timeout;
HttpWebResponse myHttpWebResponse1 = (HttpWebResponse)myHttpWebRequest1.GetResponse();
Stream receiveStream = myHttpWebResponse1.GetResponseStream();
Encoding enc = System.Text.Encoding.UTF8;
StreamReader loResponseStream = new StreamReader(receiveStream, enc);
And i get:
System.Net.WebException non è stata gestita
HResult=-2146233079
Message=Connessione sottostante chiusa: Chiusura imprevista della connessione..
Source=System
StackTrace:
in System.Net.HttpWebRequest.GetResponse()
in Arduino.Form1.aggiornadati(String action) in C:\Users\PC-Simone\Desktop\New\Arduino\Form1.cs:riga 115
in Arduino.Form1.buttonCancello_Click(Object sender, EventArgs e) in C:\Users\PC-Simone\Desktop\New\Arduino\Form1.cs:riga 53
in System.Windows.Forms.Control.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.ButtonBase.WndProc(Message& m)
in System.Windows.Forms.Button.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
in System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
in System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
in System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
in System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
in System.Windows.Forms.Application.Run(Form mainForm)
in Arduino.Program.Main() in C:\Users\PC-Simone\Desktop\New\Arduino\Program.cs:riga 18
in System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
in System.AppDomain.nExecuteAssembly(RuntimeAssembly assembly, String[] args)
in System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel)
in System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly()
in System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData)
in System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext)
in System.Activator.CreateInstance(ActivationContext activationContext)
in Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone()
in System.Threading.ThreadHelper.ThreadStart_Context(Object state)
in System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
in System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
in System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
in System.Threading.ThreadHelper.ThreadStart()
InnerException:
My Visual Studio is in italian, the translation of the message is: The underlying connection was closed: unexpected connection close.
This is the code that i use in Android (i use the OkHttp Library):
OkHttpClient client = new OkHttpClient();
Request request = new Request.Builder()
.url(params[0])
.build();
Response response = client.newCall(request).execute();
String result = response.body().string();
And i get:
java.io.IOException: unexpected end of stream on Connection
With other url the code works perfectly, but with the web page of the ESP don't work.
Any solution? Thanks!
