i've searched many hours for a solution without succes.
I tried to flash NodeMCU on my ESP12F.
I used the build from: http://nodemcu-build.com/
I have Linux and flashed via a FTDI232 with:
sudo python2 esptool/esptool.py --port /dev/ttyUSB0 write_flash 0x0000 nodemcu-master-7-modules-2016-01-29-14-59-03-integer.binAccording to the output of esptool, the flashing worked.
After resetting and changing GPIO0 from GND to VCC there evrytime comes some gibberish followed by one of this three error messages:
- Code: Select all
don't use rtc mem data - Code: Select all
Self adjust flash size. - Code: Select all
r�
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 26636, room 16
tail 12
chksum 0xa7
ho 0 tail 12 room 4
load 0x3ffe8000, len 2260, room 12
tail 8
chksum 0xe1
load 0x3ffe88d4, len 8, room 0
tail 8
chksum 0x3c
csum 0x3c
When the third error message comes, the ESP repeatedly reboots and outputs the same text again
As far as I know "rst cause:4" means watchdog reset
The ESP is connected to good power supply unit
CH_PD is pulled up
GPIO15 pulled down
VCC(FTDI) connected to VCC(ESP) and VCC of the PSU and the same with GND
RX(ESP) to TX(FTDI)
TX(ESP to RX(FTDI)
The FTDI is turned to 3.3V
I'm new to the ESP so maybe I did some fundamental errors.
I'm happy with every hint
Thanks
