I also noticed that all instructions following that function in a file get ignored. So, the following file doesn't print anything on my Nokia 5110 LCD:
pcd8544.contrast(62)
pcd8544.print(0,0,'-pcd8544LCD-')
Explore... Chat... Share...
alonewolfx2 wrote:My question:
1. Did I flash the correct bin file (0x00000 and 0x10000) to the ESP?
2. Should 0x7c000 and 0x7e000 be from Default location?
you dont need step 2 (at least for me)
which pins you are using?
