gpio.mode(0,gpio.OUTPUT)
gpio.write(0,gpio.HIGH)it stays low only for a short time and then goes high again.
So how do I disable this functionality, to use GPIO16 as a normal GPIO?
cu
Uhrheber
Explore... Chat... Share...
gpio.write(0,gpio.HIGH)It takes about 20-25 seconds for home assistant c[…]
