Sincerely
Sincerely
Explore... Chat... Share...
if not tmr.alarm(0, 300000, tmr.ALARM_AUTO, function()
print("5min is up")
end)
then print("failed to create timer")
endmarcelstoer wrote:http://nodemcu.readthedocs.io/en/master/en/modules/tmr/#tmralarmCode: Select allif not tmr.alarm(0, 300000, tmr.ALARM_AUTO, function()
print("5min is up")
end)
