But what I wrote, does not work as I need. I'm novice in Lua.
strnum=string.find(queryString,"%d+")
SetPower=tonumber(string.sub(queryString,strnum))what do I need:
"assd45sdsf12dasf45" > "45"
"wfj85694sgsd" > "856"
"welfg1a2485ab546" > "1"
Thanks
Explore... Chat... Share...
SetPower=tonumber(string.sub(queryString,strnum))pattern="[0-9][0-9]?[0-9]?"
function test(str)
print(str .. ":")
print(string.match(str,pattern))
test("assd45sdsf12dasf45")
test("wfj85694sgsd")
test("welfg1a2485ab546")
test("nodigit")
test("000atstart")
test("atend9876")
test("atend9")
assd45sdsf12dasf45:
45
wfj85694sgsd:
856
welfg1a2485ab546:
1
nodigit:
nil
000atstart:
000
atend9876:
987
atend9:
9
