How WS2812B leds should be connected to ESP8266 ?
WS2812 plug-in claims to support WS2812B, but I cannot make it work.
When I do:
ws2812.init()
ws2812.write(string.char(255,0,0))Then green light up.
ws2812.init()
ws2812.write(string.char(255,255,0))Then Yellow light up.
ws2812.init()
ws2812.write(string.char(255,255,255))Then WHITE is light up.
But there is no way of turning light off. When I do:
ws2812.init()
ws2812.write(string.char(0,0,0))Then LED stays White, this (0,0,0) has no effect.
Also codes like:
ws2812.init()
ws2812.write(string.char(0,0,255))Turn on GREEN led (works the same as (255,0,0)).
I used ESP8266 in ESP-12F form and I used something like
to shift levels between 3.3V and 5V.NodeMCU is build from master on NodeMCU Cloud Build Service.
Is there something else that must be done to control WS2812B ?
