I need something similar to "Pulsein()" function in nodemcu but i have no clue how to do that, Im trying to interface with hc-sr04 module with some results but very different than ones from arduino.
Any one know a good lib for lua?
Thks in advance
Explore... Chat... Share...
#define TRIGGER 0
#define ECHO 2 // NodeMCU Pin D0 > TRIGGER | Pin D2 > ECHO
Serial.begin (9600);
pinMode(TRIGGER, OUTPUT);
pinMode(ECHO, INPUT);
//pinMode(BUILTIN_LED, OUTPUT);
long duration, distance;
digitalWrite(TRIGGER, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO, HIGH);
distance = (duration/2) / 29.1;
Serial.print(distance);
Serial.println("Centimeter:");
delay(1000);
