short story: How do I pass parameters to callback functions in LUA?
Long story:
I'm working on an ESP8266 with the nodemcu firmware. Essentially I intend to built a dash button, just with multiple buttons per node. I'm doing this with the interrupt possibility of the gpio pins.
However it only seems to be documented how to invoke a function without passing parameters to it. But in my case I want to know for which pin the interrupt came. I googled quite a bit and came up with the approach below. It is working except for the value of the pin, that seems to reset to the initialization value of 1 when triggered.
-- Have an area to hold all pins to query (in testing only one)
buttonPins = { 5 }
direction="up"
armAllButtons()
function armAllButtons()
for i,v in ipairs(buttonPins)
do
armButton(v)
function armButton(buttonPin)
print("Arming pin "..buttonPin.." for button presses.")
gpio.mode(buttonPin,gpio.INT,gpio.FLOAT)
gpio.trig(buttonPin, direction, function (buttonPinPressed) notifyButtonPressed(buttonPinPressed) end)
print("Waiting for button press on "..buttonPin.."...")
function notifyButtonPressed(buttonPin)
print("Button at pin "..buttonPin.." pressed.")
--rearm the pins for interrupts
gpio.trig(buttonPin, direction, notifyButtonPressed)
endHowever from within the function notifyButtonPressed() the value of buttonPin is always 1 when pressed, not 5 as I would expect it to be. I'd assume that's probably the initialization value of number variables.
Does anybody have an idea?
