file.writeline('wifi.sta.config("'..myssid..'","'..mypassword..'")')inside my code i receive a tons of strange character and the procedure doesn't work at all ?
If i exclude this line or if i replace variables with text everything works fine.
Explore... Chat... Share...
file.writeline('wifi.sta.config("'..myssid..'","'..mypassword..'")') file.writeline("wifi.sta.config(\""..myssid.."\",\""..mypassword.."\")")It takes about 20-25 seconds for home assistant c[…]
