can some one please give me a hint why this script crash the ESP?
It does not do
tmr.alarm(1, 1000, 1, function() if finished == 0 then sendTemp() end end)
print("Heap0: "..node.heap())
local humi=9999
local h
local temp=9999
local t
local finished=0
PIN = 6 -- data pin, GPIO12
function ReadDHT22()
print("Heap before DHT22: "..node.heap())
dht22 = require("dht22_min")
dht22.read(PIN)
t = dht22.getTemperature()
h = dht22.getHumidity()
if t == nil then
print("t is nill! Error Reading!")
humi=9999
temp=9999
temp=(t/10)
if h ~= nil then
humi=(h/10)
print("Humidity: "..humi.."%")
print("h is nill! Error Reading!")
print("Temperature: "..temp.." deg C")
dht22 = nil
package.loaded["dht22_min"]=nil
h = nil
t = nil
print("Heap after DHT22: "..node.heap())
function sendTemp()
print("Heap before sendTemp"..node.heap())
if temp ~=9999 then
m:connect("192.168.0.1", 1883, 0, function(conn)
print("connected")
m:publish("sensors/test/temp",temp,0,0, function(conn)
print("sent temp")
finished=finished+1
temp = nil
--tmr.stop(1)
end)
m:close()
end)
print("bad temp data!")
finished=finished+1
tmr.stop(0)
print("Heap after sendTemp"..node.heap())
function sendHumi()
if humi ~=9999 then
print("connected")
m:publish("sensors/test/humi",humi,0,0, function(conn)
print("sent humi")
finished=finished+1
humi = nil
--tmr.stop(2)
end)
--end)
m:close()
end)
print("bad humi data!")
finished=finished+1
tmr.stop(1)
m = mqtt.Client(wifi.sta.getmac(), 10)--, "user", "password")
---m:lwt("/lwt", wifi.sta.getmac(), 0, 0)
m:on("offline", function(con)
print ("offline!")
if finished == 2 then
print ("Clean up!")
m = nil
finished = nil
print ("going to sleep a bit...")
--node.dsleep(6000000)
print ("Not ready to sleep yet!")
--print("Heap after offline: "..node.heap())
end)
print("Heap1: "..node.heap())
if wifi.sta.status() == 5 then
print("status ok")
ReadDHT22()
--sendTemp()
--sendHumi()
tmr.alarm(1, 1000, 1, function() if finished == 0 then sendTemp() end end )
tmr.alarm(2, 1000, 1, function() if finished == 1 then sendHumi() end end )
print("WIFI Status not 5!")
print("Heap end: "..node.heap())
Out put is:
NodeMCU 0.9.5 build 20150213 powered by Lua 5.1.4
lua: cannot open init.lua
> dofile('dht2mqtt3.lua')
Heap0: 11776
Heap1: 8664
status ok
Heap before DHT22: 8608
Temperature: 19.7 deg C
Heap after DHT22: 5864
Heap end: 5880
> c_ÇÏRSöJSúfJSúfêá
