please excuse my bad english.
I had a problem with reboots in my script. sometimes it reboot. Anyone have an idea?
The script reboot the most time after splitting and post the text on oled.
(wifi.sta.config infos deleted)
wifi.sta.config("SSID","password")
linelength =24
wifi.sta.setip({ip="192.168.178.111",netmask="255.255.255.0",gateway= "192.168.178.1"})
oled.setup(4,3)
oled.clear()
oled.invert(0)
oled.line(1, 1, wifi.sta.getip() )
print(wifi.sta.getip())
srv=net.createServer(net.TCP) srv:listen(80,function(conn)
inputs = {}
payload = payload:gsub("%%3A+", ":")
payload = payload:gsub("%%5B", "")
payload = payload:gsub("%%5D", "")
payload = payload:gsub("+", " ")
if string.match(payload, "(text1)=(.+)") then
for k, teilstring in string.gmatch(payload,"(text1)=(.+)") do
inputs[k] = teilstring
payload = nil
if inputs.text1 ~= nil then
splitedtxt = split(inputs.text1, linelength)
inputs.text1 = nil
oled.clear()
for i = 1 , #splitedtxt do
oled.line(i, 1, splitedtxt[i])
splitedtxt[i] = nil
tmr.delay(1000)
conn:send('HTTP/1.1 200 OK\n\n')
conn:send('<!DOCTYPE HTML>\n')
conn:send('<html>\n')
conn:send('<head><meta content="text/html; charset=utf-8">\n')
conn:send('<title>EasyPlay</title></title>\n')
conn:send('<body><h1>EasyPlay</h1>\n')
conn:send('<form action="" method="POST">\n')
conn:send('<input type="text" name="text1" size="25" value="AAAAAAA"><br>\n')
conn:send('<input type="submit" value=" send ">')
conn:send('</form></body></html>\n')
print("connection closed")
end)
end)
function split(str, max_line_length)
local lines = {}
local line
str:gsub('(%s*)(%S+)',
function(spc, word)
if not line or #line + #spc + #word > max_line_length then
table.insert(lines, line)
line = word
line = line..spc..word
return lines
endI use "NodeMCU 0.9.5 build 20150127" with oled support from this thread. I want to understand the issue.
greetings & thanks
Alex
Edit: add link
