By 3ed9a386f9
#11287 I have an ESP01 module with a LUA script that works fine. It's just a script that gets a web URL when a switch changes position. It's set up to run through init.lua and this works fine too.
Apart from when I unplug my USB serial adapter from the board. Then it doesn't work.
Clearly it's very hard to find out why when there's no USB adapter plugged in.
I've got a good separate 3.3v supply to the board - the only connections between the ESP01 and the USB adapter are ground, tx, rx. Nothing else.
Is this a known issue?
Cheers!
