Has anyone got an example code for detecting long/short "button presses" on a gpio line?
I can't seem to get it working what with debouncing and seemingly missed interrupts..
Cheers!
Che
Explore... Chat... Share...
count = 0
pulse1 = 0
du = 0
gpio.mode(4,gpio.INT,gpio.PULLUP)
function pin1cb(level)
du = tmr.now() - pulse1
if du > 10000000 then
count = count + 1
pulse1 = tmr.now()
if level == 1 then gpio.trig(4, "down") else gpio.trig(4, "up") end
endIt takes about 20-25 seconds for home assistant c[…]
