I'm having some trouble with the following code:
wifi.setmode(wifi.STATION)
wifi.sta.setmac("\002\001\002\003\003\006")
wifi.sta.config("XXX","YYY")
stripPin = 4 -- Comment: GPIO2
local data
s=net.createServer(net.UDP)
s:on("receive",function(s,c)
for i = 126, 276 do
data = data .. string.char(c,i)
ws2812.writergb(stripPin, data) end)
s:listen(5568)I'm trying to pass a string from the incoming UDP data (bytes 126 through 276) to the ws2812 function. The line data = data .. string.byte(c,i) throws an error. Here is the error:
PANIC: unprotected error in call to Lua API (init.lua:18: attempt to concatenate local 'data' (a nil value))
I'm sure I'm not passing this data correctly. Any help would be greatly appreciated.
