Works fine.
Embed it in SCITE.
As a result, it is not necessary to download the source files lua,
and you can immediately ship the byte code in the ESP.
Explore... Chat... Share...
> esp-cmd -h
usage: esp-cmd [options] [filenames]
example:
>esp-cmd -i -c fred.lua -i -l
options with no parameters:
-i prints memory and version information for the ESP8266
-h prints this usage information
-l print file listing for ESP8266
-b reformat ESP8266 and restore minimum bootstap files
-r restart ESP8266 after 2s delay
options with file parameter
-c <file> download and compile the specified file on the ESP8266
-d <file> download the specified file name to the ESP8266
-u <file> upload the specified file name from the ESP8266
options with two file parameters
-m <from> <to> move the specified file within the ESP8266 file system
Note that the specified file name may include an optional path. This is applied
to the local file naming but is ignored for the ESP8266 filename. So the
following example downloads /tmp/mytable.txt to mytable.txt on the ESP8266:
>esp-cmd -d /tmp/mytable.txt
options with csv parameters
-x cmd,params Execute command "cmd" with parameters "params"
-X cmd,params <file> Execute command "cmd" with parameters "params" and
attach blob given in file.
