- Tue May 05, 2015 12:38 pm
#16604
Nubble wrote:TerryE: you said you would would post a guide to save memory in nodeMcu scripts. Any update?
Sorry, still on my todo list
I think that the main thing is that Lua essentially fields an event with associated with subroutine invocation which runs to completion at which it the garbage collects any disused code and data and optionally waits for the the next event to fire.
Events can be things like timer alarms, network on() events, an many of the hardware drivers can have associated events as well. So just make sure that you don't keep in scope links that you don't need -- e.g.
- If an event routine has upvalues then its defining routing can't be garbage collected etc., and if has locals pointing to other functions then they might not get collected either: upvalues are bad news for event routines. Stick to globals if you want to pass context into them unless you really understand the consequences
- Some event handlers don't properly reference their accociated event functions hence doing things like:
Code: Select alltmr.alarm(x,10000,0,print) tmr.stop(x)
wifi.sta.getap(type) - just remember that variables hold table and functions s by reference, so it is easy to collect multiple references accidentally, and as long as one stasg in scope, then the table can't be collected..
- For example require"rtn" generates an entry package.loaded.rtn equal to the loadfile function.
My framework contains the following handler
Code: Select allLoad = setmetatable(
{ip = c.ip, name= "Load"},
{__index = function (this,key)
if key:sub(1,1)=='_' then return nil end
return require(this.name.."_"..key)
where Load is one of the few globals. Hence if I have
Load_fred.lua or
Load_fred.lc which is a straight loadsource-type function which uses
... to read its parameters. So long as this includes the line
Code: Select allpackage.loaded.Load_fred = nil -- make routine effemeral then I can happily do a
knowing that it will be loaded on demand, run and vanish like a ghost.
But what about the load overhead you may ask. Well you can time loading an lc form of a 100 line long script -- it's under 1 mSec, -- hardly an issue for an IoT device, eh?
Please see my
Developer FAQ for Q&A on nodeMCU Lua before asking a question here that's already been answered. This and the other official documentation should be your first reference for developing Lua Apps
