By canibalimao
#18161 Hi,
I want to make a log on ThingSpeak of the temperatures all over my house (I'll place some ESP8266+DS12B20 modules in some rooms and outside) but I also want to make each ESP8266 a web server where I can see the instant temperature on each place.
Is this possible? The ESP8266 can deal with this job (deal with the incoming web requests and send info to a server)?
Thanks in advance
By canibalimao
#18181 Forget this. I've tried to make this and, after a few failures, I got this working! Now I just need to take this out of the breadboard and install this first unit outside :D
Then I'll want to make this accessable over any internet access point in the world, so I'll nees to find, finally, how to open the ports on my Thomson router :evil:
By canibalimao
#18511 I have found this code somewhere arround the web, but now I don't know where it was :|
You have to put these 3 files on you ESP:
ds18b20.lua (this is a library available on the nodeMCU github, I think)
Code: Select all--------------------------------------------------------------------------------
-- DS18B20 one wire module for NODEMCU
-- NODEMCU TEAM
-- LICENCE: http://opensource.org/licenses/MIT
-- Vowstar <vowstar@nodemcu.com>
-- 2015/02/14 sza2 <sza2trash@gmail.com> Fix for negative values
-- Set module name as parameter of require
local modname = ...
local M = {}
_G[modname] = M
-- Local used variables
-- DS18B20 dq pin
local pin = nil
-- DS18B20 default pin
local defaultPin = 9
-- Local used modules
-- Table module
local table = table
-- String module
local string = string
-- One wire module
local ow = ow
-- Timer module
local tmr = tmr
-- Limited to local environment
setfenv(1,M)
-- Implementation
C = 0
F = 1
K = 2
function setup(dq)
  pin = dq
  if(pin == nil) then
    pin = defaultPin
  ow.setup(pin)
function addrs()
  setup(pin)
  tbl = {}
  ow.reset_search(pin)
  repeat
    addr = ow.search(pin)
    if(addr ~= nil) then
      table.insert(tbl, addr)
    tmr.wdclr()
  until (addr == nil)
  return tbl
function readNumber(addr, unit)
  result = nil
  setup(pin)
  flag = false
  if(addr == nil) then
    count = 0
    repeat
      count = count + 1
      tmr.wdclr()
    until((addr ~= nil) or (count > 100))
    return result
  crc = ow.crc8(string.sub(addr,1,7))
  if (crc == addr:byte(8)) then
    if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
      -- print("Device is a DS18S20 family device.")
      ow.reset(pin)
      ow.select(pin, addr)
      ow.write(pin, 0x44, 1)
      -- tmr.delay(1000000)
      present = ow.reset(pin)
      ow.write(pin,0xBE,1)
      -- print("P="..present)
      data = nil
      data = string.char(ow.read(pin))
      for i = 1, 8 do
        data = data .. string.char(ow.read(pin))
      -- print(data:byte(1,9))
      crc = ow.crc8(string.sub(data,1,8))
      -- print("CRC="..crc)
      if (crc == data:byte(9)) then
        t = (data:byte(1) + data:byte(2) * 256)
        if (t > 32767) then
          t = t - 65536
        if(unit == nil or unit == C) then
          t = t * 625
        elseif(unit == F) then
          t = t * 1125 + 320000
        elseif(unit == K) then
          t = t * 625 + 2731500
          return nil
        t = t / 10000
        -- print("Temperature="..t1.."."..t2.." Centigrade")
        -- result = t1.."."..t2
        return t
      tmr.wdclr()
    -- print("Device family is not recognized.")
  -- print("CRC is not valid!")
  return result
function read(addr, unit)
  t = readNumber(addr, unit)
  if (t == nil) then
    return nil
    return t
-- Return module table
return M
dallas.lua
Code: Select allrequire('ds18b20')
port = 80
-- ESP-01 GPIO Mapping
gpio0 = 3
ds18b20.setup(gpio0)
function sendData()
t1=ds18b20.read()
t1=ds18b20.read()
print("Temp:"..t1.." C\n")
-- conection to thingspeak.com
print("Sending data to thingspeak.com")
conn=net.createConnection(net.TCP, 0)
conn:on("receive", function(conn, payload) print(payload) end)
-- api.thingspeak.com 184.106.153.149
conn:connect(80,'184.106.153.149')
conn:send("GET /update?key=THINGSPEAKKEY&field1="..t1.." HTTP/1.1\r\n")
conn:send("Host: api.thingspeak.com\r\n")
conn:send("Accept: */*\r\n")
conn:send("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n")
conn:send("\r\n")
conn:on("sent",function(conn)
                      print("Closing connection")
                      conn:close()
                  end)
conn:on("disconnection", function(conn)
          print("Got disconnection...")
  end)
-- send data every X ms to thing speak
tmr.alarm(0, 900000, 1, function() sendData() end )
srv=net.createServer(net.TCP)
srv:listen(port,
     function(conn)
          conn:send("HTTP/1.1 200 OK\nContent-Type: text/html\nRefresh: 5\n\n" ..
              "<!DOCTYPE HTML>" ..
              "<html><body>" ..
              "<b>ESP8266</b></br>" ..
              "Temperature : " .. ds18b20.read() .. "<br>" ..
              "Node ChipID : " .. node.chipid() .. "<br>" ..
              "Node MAC : " .. wifi.sta.getmac() .. "<br>" ..
              "Node Heap : " .. node.heap() .. "<br>" ..
              "Timer Ticks : " .. tmr.now() .. "<br>" ..
              "</html></body>")
     end)
(dont forget to change THINGSPEAKKEY to yours)
init.lua
Code: Select allprint(wifi.sta.getip())
wifi.setmode(wifi.STATION)
wifi.sta.config("WiFiSSID","WiFiPassword")
dofile('dallas.lua')
