I need a faster pwm than the one that is included that is why i am doing this.
This one is not working when i try to use the "tmr" as local variable, the tmr.delay just don't do anything in this case.
function forwardandrewind()
local tmr = tmr
if(forward == 1) then
forward = 0
gpio.write(3,gpio.HIGH)
forward = 1
gpio.write(3,gpio.LOW)
for x=1,16000 do
gpio.write(4,gpio.HIGH)
tmr.delay(1)
gpio.write(4,gpio.LOW)
tmr.delay(1)
tmr.wdclr()
tmr = nil
print(node.heap())
This one is working when i try to use the "tmr" but leak memory.
forward = 0
forward = 1
for x=1,16000 do
tmr.delay(1)
tmr.delay(1)
tmr.wdclr()
tmr = nil
print(node.heap())
endAny suggestions?
