By joefly888
#20500 I got a simple script that is basically tmr.alarm every 10seconds calls a function to do a http POST request to ubidots.com
I noticed my script each time it "loops" I print out the heap, it decreased by varying amounts from a few to over 100 kb. It runs for awhile before crashing due to lack of memory.
The HTTP connection is closed, I continually use the same variables.
What could be causing the HEAP leakage? Is there something in particular in my code that I should be careful of or investigate?
By joefly888
#20560 hello DNC, I thought it was my code, so I started tracking it down and it is happening even when no code is running.
after file.format()
I have this init.lua running
Code: Select allprint (node.heap())
print (node.heap())
print (node.heap())
print (node.heap())
print (node.heap())
tmr.alarm(0,5000, 1, print(node.heap() ))
this is the output
Code: Select allNodeMCU 0.9.5 build 20150214  powered by Lua 5.1.4
21336
20992
20952
20912
20872
20832
notice the decreasing node count. Again, after file.format() and each restart, the same node output, so it is consistent, at least in this code. I also run print(node.heap()) in esplorer terminal after this output and see that it recovered and stabilizes at 22688.
also a separate problem. My is my tmr.alarm not running at all?
is this a bug?
By joefly888
#20564 Given my code stabilizes at 22688 and assuming this is not a bug
I run this code and I get continual decreasing heap.
Code: Select alltempPin = 3  --gpio00 for temp
motion = 7 --gpio13 for motion detection
door = 1 -- gpio05 for door sensor
gpio.mode(motion, gpio.INPUT)
gpio.mode(door, gpio.INPUT)
function gettemp()
   t = require("ds18b20")
   t.setup(tempPin)
   addrs = t.addrs()
   if (addrs ~= nil) then
     print("Total DS18B20 sensors: "..table.getn(addrs))
   temp = t.read()
   print ("before ..."..node.heap())
   -- Don't forget to release it after use
   t = nil
   ds18b20 = nil
   package.loaded["ds18b20"]=nil
   print ("after ..."..node.heap())
function sendData()   --- Post new datapoints to ubidots
    print("Sending data to ubidots.com")     -- conection to ubidots.com
    connout = nil
    connout = net.createConnection(net.TCP, 0)
    connout:on("receive", function(connout, payloadout)
        if (string.find(payloadout, "201 CREATED") ~= nil) then
            print("Posted OK");
    end)
    function postIt (varName, idvariable, value)
        print ("Posting "..varName..": "..value..".....");
        local postval = "POST /api/v1.6/variables/"..idvariable.."/values HTTP/1.1\n"
          .."Content-Type: application/json\n"
          .."Content-Length: "..(string.len(value)+11).."\n"   -- length of {"value": '..value..'}'
          .."X-Auth-Token: ubidotstoken\n"
          .."Host: things.ubidots.com\n\n"
          ..'{"value": '..value..'}\n\n';
        connout:send(postval)
     connout:on("connection", function(connout, payloadout)
        gettemp()
        postIt("Temp", "ubidotsID1", temp)
        postIt("Volt", "ubidotsID2", node.readvdd33() / 1000)
        postIt("Door", "ubidotsID3", gpio.read(door))
        print("heap: "..node.heap())
    end)
    connout:on("disconnection", function(connout, payloadout)
        connout:close();
        collectgarbage();
        print("disconnect")
    end)
    connout:connect(80,'things.ubidots.com')
-- send data every X ms to ubidots
tmr.alarm(0, 10000, 1, function() sendData() end )
