I have a little problem with my esp.... i´m despairing!
Here's my Code:
port = 80
srv=net.createServer(net.TCP)
OSS = 2 -- oversampling setting (0-3)
SDA_PIN = 4 -- sda pin, GPIO2
SCL_PIN = 3 -- scl pin, GPIO0
bmp180 = require("bmp180")
bmp180.init(SDA_PIN, SCL_PIN)
bmp180.read(OSS)
t = bmp180.getTemperature()
p = bmp180.getPressure()
srv:listen(port,
function(conn)
conn:send("HTTP/1.1 200 OK\nContent-Type: text/html\nRefresh: 5\n\n" ..
"<!DOCTYPE HTML>" ..
"<html><body><b>OutdoorSensor</b><br>" ..
(p/100) ..
"<br>" ..
(t/10) ..
"</html></body>")
-- release module
bmp180 = nil
package.loaded["bmp180"]=nil
It displays the data from a BMP180 sensor on a simple HTML page. Now the Problem: It doesn't refreshes the data - the values are saved until i reboot my esp. But logically, it should display me the new values when i refresh the web-page...
Can you help me?
