By Defozo
#24708 Hello, I need to connect to my server on PC (socket connection) after initialization of WiFi connection.
For now I have 2 files:
init.lua
Code: Select allwifi.setmode(wifi.STATION)
wifi.sta.config("mySSID","myPassword")
socket.lua
Code: Select allsk=net.createConnection(net.TCP, 0)
sk:on("receive", function(sck, c) print(c) end )
sk:connect(7171,"54.325.231.532")
sk:send("test123")
print('done')
I want to run socket.lua automatically after connection to the WiFi Hotspot has been established.
I've tried to modify this example code:
Code: Select all-- choose the strongest open AP available and connect to it
-- Autoconnect to strongest AP
-- tested with NodeMcu 0.9.2 build 20141212
ConnStatus = nil
function ConnStatus(n)
status = wifi.sta.status()
uart.write(0,' '..status)
local x = n+1
if (x < 50) and ( status < 5 ) then
   tmr.alarm(0,100,0,function() ConnStatus(x) end)
   if status == 5 then
   print('\nConnected as '..wifi.sta.getip())
   print("\nConnection failed")
best_ssid = nil
function best_ssid(ap_db)
local min = 100
for k,v in pairs(ap_db) do
    if tonumber(v) < min then
       min = tonumber(v)
       ssid = k
best = nil
function best(aplist)
ssid = nil
print("\nAvailable Open Access Points:\n")
for k,v in pairs(aplist) do print(k..' '..v) end
ap_db = nil
ap_db = {}
if nil ~= next(aplist) then
      if '0' == string.sub(v,1,1) then
         ap_db[k] = string.match(v, '-(%d+),')
   if nil ~= next(ap_db) then
      best_ssid(ap_db)
if nil ~= ssid then
   print("\nBest SSID: ".. ssid)
   wifi.sta.config(ssid,"")
   print("\nConnecting to "..ssid)
   ConnStatus(0)
   print("\nNo available open APs")
wifi.sta.getap(function(t) best(t)  end)
Modified:
Code: Select allConnStatus = nil
local x = n+1
   if status == 5 then
   dofile("socket.lua")
ConnStatus(0)
It works, however sometimes the connection to the server lasts for only few seconds. It must stay alive all the time.
Any ideas?
Thanks in advance,
Defozo
