By joebro391
#25617 Okay, so I'm aware that there is already a very similar post regarding this topic, however that thread has seemed to die and I am encountering a slightly different problem, along with some very interesting issues when I apply power to my ESP8266.
Preface: I am still quite new to the ESP8266, however I followed both Julian Ilett's video guide to setting up mine (successfully) as well as Hari Wiguna's.
I have flashed the module with NodeMCU Flasher Master and it uploaded successfully. I initially started utilizing LuaUploader and successfully uploaded a simple Web Page with toggle pin (toggling on a LED). It works absolutely fine. I then decided to save the file to the ESP8266, of course naming it "init.lua". When I disconnect my 3.3V USB-to-Serial adapter (the unit remains powered through a 3.3 voltage regulated circuit) the web page continues to work perfectly (i did notice however that only after I have removed the USB-to-Serial adapter, that a blue light begins to flash on the ESP8266). Then I unplug the power supply, plug it back in and NOTHING.
NOTE*** The USB-to-Serial adapter does NOT power the ESP8266. Although the share a common Gnd, the 3.3V pin from the USB-to-Serial adapter is not connected to anything and left "floating".
WEIRD TWIST: I plug back in the USB-to-Serial Adapter and then unplug the power supply to "reset" the ESP8266, and the web page goes right back online like nothing happened. Note, I did NOT re-upload anything. LuaUploader can be completely closed out and this still happens.
I go back to LuaUploader and press "List Files" and it says "name:init.lua, size:1201". So it's there...I try the process of deleting and re-saving it, followed by trying to overwrite the file, but the same issue occurs.
I then open up ESPlorer v0.2.0-rc2 and connect successfully, press "FS Info" and get:
Total : 549941 bytes
Used : 1506 bytes
Remain: 548435 bytes
so I enter "file.remove("init.lua")"
and then "FS Info" again and get
Used : 0 bytes
Remain: 549941 bytes
Close the connection, BUT THE WEB PAGE STILL WORKS!!! All the while the USB-to-Serial is still plugged in. But then when I remove power from the ESP8266 and apply power, nothing (as it should be).
So now I have a blank ESP8266. Now I go to ESPlorer and put in the same code. Open the connection, select "Save to ESP", close connection and the web page runs perfectly. Do the same thing again: remove power...apply power (while USB-to-Serial is connected) and everything works good. Remove USB-to-Serial adapter, remove power from ESP8266, reattach power...nothing. But if I reattach the USB-to-Serial adapter, then reattach power to the ESP8266, works fine.
What the hell is going on? Is the USB-to-Serial sending some type of reset message to the module? How do I get this working from just a boot-up? Am I forgetting to tie a certain pin HIGH or LOW? I don't know, but it's freaky.
Please let me know if you need any additional information. Thank you all so much in advance.
-Joe
By erj
#26823 +1 I'm having the exact same problem. Flashed nodeMCU firmware, no problem. Used esplorer and sent init.lua. connects to router just fine when hooked up to the ftdi programmer, disconnect and then wire it to my circuit and it doesn't connect to the router after boot. Tried with 2 different esp8266's and get the same results.
By ketan
#45915
joebro391 wrote:Okay, so I'm aware that there is already a very similar post regarding this topic, however that thread has seemed to die and I am encountering a slightly different problem, along with some very interesting issues when I apply power to my ESP8266.
Used : 1506 bytes
Used : 0 bytes
-Joe
Is the problem solved? .If yes how?
Thank You
