It all happens pretty fast. Im using the ESPlorer IDE, im trying to either update the init file with a new one, send a file.remove("init.lua") command, or use the Format button but all seem to fail due to the node rebooting before any of the commands execute.
Is there any tool/command to abort the current script? or to erase the file system?
I tried to flash the node with new firmware but that did not affect current behavior.
using nodemcu amica, if that makes a difference
