After loading a couple of example sketches using the Arduino IDE and having problems I decided to reflash the LUA code and get back to a known starting point. I downloaded the nodemcu flasher software. Inside the zip file are two executables, one for 32-bit systems and one for 64-bit systems. Since I'm using Windows10 I tried using the 64-bit version first. After selecting the right COM port the software appeared to re-flash the module and indicated success. However, after resetting it, and trying to connect with PuTTY I only get random characters on the screen. I've flashed the module several times using different baud rates and flash speeds without any success. (I'm using a SparkFun FTDI 3.3V Basic module for a USB interface with my PC.)
What am I doing wrong and what can I do to get the LUA software to work again?
