Right now I'm using:
pwm.setup(3,100,61)
pwm.start(3)
Am I doing that correctly? The servo requires a pulse for 1.3ms then a pause for 20ms. Can anybody double check this to see if I'm doing it correctly? This is all still pretty new to me.
Explore... Chat... Share...
