Is there a command to check if a file exist in LUA ? Something like: file.exist(filename)?
Hans
Explore... Chat... Share...
> =file.open("init.txt","r")
lua: stdin:1: cannot open file
> zeroday wrote:file.open("init.lua","r") or file.open("init.lua")
if init.lua not exist, a error shows.
in next release this api will return a nil if the file not exists.
if file.list()[filename] then ....It takes about 20-25 seconds for home assistant c[…]
