By the way, is there any reason cause adc.read alway return 65535?
Thank you for any support in advance
Explore... Chat... Share...
// Byte 107 of esp_init_data_default, only one of these 3 can be picked
//#define ESP_INIT_DATA_ENABLE_READVDD33
#define ESP_INIT_DATA_ENABLE_READADC
//#define ESP_INIT_DATA_FIXED_VDD33_VALUE 33python ./esptool.py --port /dev/tty.SLAB_USBtoUART --baud 115200 write_flash -fm=dio -fs=32m 0x00000 nodemcu-master-11-modules-2016-03-28-13-48-40-float-adcread.bin
