By donnib
#36055 Hi,
For some reason i can't flash my board with esptool anymore, the board works, it runs the previous program (i can see serial output)
i run
Code: Select allsudo python esptool.py --baud 115200 --port /dev/tty.usbserial-A40081xF write_flash 0x00000 ~/Downloads/nodemcu-master-8-modules-2015-12-08-21-26-15-float.bin
then i get output
Code: Select allConnecting...
Erasing flash...
Writing at 0x00000000... (0 %)
A fatal error occurred: Failed to write to target Flash after seq 0 (got result 0x1, 0x8)
Any ideas what's wrong ?
By donnib
#36095 This drives me crazy !
I know the FTDI is working fine sine i have another module that i can flash fine. It's just this module which i can't flash anymore. I even tried Arduino IDE which seems to flash but then i can see it's still the same code that's in the module so the flash did not do anything eventhough the led flashes there is data transmitted !!! :shock: :shock:
How is that possible ? Is is writing to a wrong place ? If so how in the h... can i wipe everything to get back to normal ?
donnib
By JeremiahLandi
#36118 Hey Guys!
I normally post these up in the firmware question but who knows. I am not 100% about posting things around here.
Are you able to connect the device to ESPlorer or putty?
EDIT: Some info from around Google that is just good to know..
What to do when ESP8266 will not flash (http://internetofhomethings.com/homethings/?p=538)
