Has anyone had issues with GPIO interrupts not firing?
I've used 'both' trig mode to trigger on rising and falling edge:
local PIN1 = 4
local PIN2 = 2
function debounce (func)
local last = 0
local delay = 200000
return function (...)
local now = tmr.now()
if now - last < delay then return end
last = now
return func(...)
function onChange ()
print('Pin1= '.. gpio.read(PIN1) .. ', Pin2= ' .. gpio.read(PIN2))
gpio.mode(PIN1, gpio.INT)
gpio.mode(PIN2, gpio.INT)
gpio.trig(PIN1, 'both', debounce(onChange))
gpio.trig(PIN2, 'both', debounce(onChange))
It frequently doesn't trigger when one of the pins toggles.
However if I read the GPIO pin manually later, I can see that the pin state has changed. But no interrupt was generated (or at least didn't make it through the debounce function).
I've had to resort to polling the GPIO every few seconds on a timer in order to capture any changes in GPIO state. Any hints would be appreciated.
