By mfkfx1
#40845 Hello,
following this tutorial:
http://www.esp8266-projects.com/2015/04 ... -time.html
I created a file ds3231.lua with the following content:
Code: Select allfunction decToBcd(val)
    local d = string.format("%d",tonumber(val / 10))
    local d1 = tonumber(d*10)
    local d2 = val - d1
   return tonumber(d*16+d2)
function bcdToDec(val)
      local hl=bit.rshift(val, 4)
      local hh=bit.band(val,0xf)
     local hr = string.format("%d%d", hl, hh)
     return string.format("%d%d", hl, hh)
address = 0x51 -- A2, A1, A0 = 0
id=0
init = function (self, sda, scl)
      self.id = 0
     i2c.setup(self.id, sda, scl, i2c.SLOW)
readTime = function (self)
   wkd = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday" }
   i2c.start(self.id)
   i2c.address(self.id, self.address, i2c.TRANSMITTER)
   i2c.write(self.id, 0x00)
   i2c.stop(self.id)
   i2c.start(self.id)
   i2c.address(self.id, self.address, i2c.RECEIVER)
   c=i2c.read(self.id, 7)
   i2c.stop(self.id)
   return  bcdToDec(string.byte(c,1)),
         bcdToDec(string.byte(c,2)),
         bcdToDec(string.byte(c,3)),
         wkd[tonumber(bcdToDec(string.byte(c,4)))],
         bcdToDec(string.byte(c,5)),
         bcdToDec(string.byte(c,6)),
         bcdToDec(string.byte(c,7))
setTime = function (self, second, minute, hour, day, date, month, year)
   i2c.start(self.id)
   i2c.write(self.id, decToBcd(second))
   i2c.write(self.id, decToBcd(minute))
   i2c.write(self.id, decToBcd(hour))
   i2c.write(self.id, decToBcd(day))
   i2c.write(self.id, decToBcd(date))
   i2c.write(self.id, decToBcd(month))
   i2c.write(self.id, decToBcd(year))
   i2c.stop(self.id)
When I try to use this new "module" from another file (i2c_ds3231.lua) with the example code:
Code: Select allrequire('ds3231')
sda, scl = 2, 1
ds3231:init(sda, scl)
s, m, h, d, dt, mn, y = ds3231:readTime()
I get the following error:
i2c_ds3231.lua:3: attempt to index global 'ds3231' (a nil value)
Can you tell me what I did wrong?
Thank you very much!
By mfkfx1
#40854 Unfortunately the same error:
Code: Select all> print(ds3231:readTime())
stdin:1: attempt to index global 'ds3231' (a nil value)
Do I need something like
Code: Select alllocal moduleName = ...
local M = {}
_G[moduleName] = M
return M
to make this a real "module"?
By xtal
#40857 I have not used any modules....so cannot help
I would try a very simple program to use the DS3231[without using require] to get it working ,
then try putting into module or what ever.
There is something called FlashMod that uses modules in flash to save ram ...myself I'll use require
I looked at the project and it confuses me....
For testing, pack it together and save the code on ESP as 'ds3231.lua', restart ESP and run:
Did you do the above step....
Using REQUIRE
I write simple function [ with no internal functions]
I write the function to FLASH -- I'm using ESPlorer v 0.2
Hope this helps...
Code: Select alllocal function LBuf(scnt,c)
   LBx = require("LB"..scnt)               --Load flash finction  LB0,LB1,LB2
   local cbuf = LBx.B0()                         -- execute function
   vt[scnt] = #cbuf
     if #cbuf>=1455 then
       c:send(scnt.."---C Buffer > 1455 Error---\r\n")
       c:send(cbuf)
   cbuf = nil                                                       -- release buffer
   package.loaded["LB"..scnt]=nil         -- release memory
   collectgarbage()
-- this is written into flash as LB0.lua
local LB0 = {}
function LB0.B0()
    local cbuf = '<!DOCTYPE HTML>\n<html lang="en-US">\n<head><meta http-equiv="refresh" content="'
      ..rfh..'" ></head>'
      ..'<script type = "text/javascript">\nvar timeInSecs;\nvar ticker;'
      ..'function startTimer(secs){ timeInSecs = parseInt(secs)-1; ticker = setInterval("tick()",1000); }'
      ..'function tick() { var secs = timeInSecs; if (secs>0) {timeInSecs--;} else {clearInterval(ticker); startTimer('..rfh..');}'
      ..'document.getElementById("countdown").innerHTML = secs;} startTimer('..rfh..'); </script>'
      ..'<body><table bgcolor="Lawngreen" border="1" cellpadding="5">'
      ..'<tr><th><h3>ESP8266</h3><h3>'..vt.device..'</h3></th><th><h3>-SDK-</h3><h3>NodeMCU</h3></th>'
      ..'<th><h3>'..yver..'</h3><h3>'..vt.sware..'</h3></th><th><h3>AAA</h3><h3>BBB</h3></th>'
      ..'<td><IMG SRC="'..vt.s_img..'" LEFT="1" WIDTH="120" HEIGHT="60" BORDER="1"></td>'
      ..'<th><h3 id="countdown">'..rfh..'</h3><h3>'..vt.pass..'</h3></th></tr>'
      ..'<th bgcolor="Cyan">'..vt.mac..'</th><th bgcolor="Yellow">'..vt.ipa..'</th>'
      ..'<th>'..vt.pass..'</th><th>'..vt.pass..'</th><th>BAUD = '..vt.baud..'</th>'
      ..'<th>Refresh = '..vt.rfh..'</th>' --</tr>'
      ..'</table><br>'
     return cbuf
 return LB0
