I created the following module:
local ds3231_m = {}
---------- Local variables ---------------------
local id = 0
local address = 0x68
---------- Helper functions --------------------
function bcdToDec(val)
local hl=bit.rshift(val, 4)
local hh=bit.band(val,0xf)
local hr = string.format("%d%d", hl, hh)
return string.format("%d%d", hl, hh)
function decToBcd(val)
local d = string.format("%d",tonumber(val / 10))
local d1 = tonumber(d*10)
local d2 = val - d1
return tonumber(d*16+d2)
---------- Module functions --------------------
function ds3231_m.Init(sda, scl)
i2c.setup(id, sda, scl, i2c.SLOW)
return
function ds3231_m.PrintTime()
i2c.start(id)
i2c.address(id, address, i2c.TRANSMITTER)
i2c.write(id, 0x00)
i2c.stop(id)
i2c.start(id)
i2c.address(id, address, i2c.RECEIVER)
c=i2c.read(id, 7)
i2c.stop(id)
s = bcdToDec(string.byte(c,1))
m = bcdToDec(string.byte(c,2))
h = bcdToDec(string.byte(c,3))
time=string.format(" %s:%s:%s", h, m, s)
print(time);
return nil
function ds3231_m.PrintDate()
i2c.start(id)
i2c.write(id, 0x00)
i2c.stop(id)
i2c.start(id)
c=i2c.read(id, 7)
i2c.stop(id)
wkd = bcdToDec(string.byte(c,4))
day = bcdToDec(string.byte(c,5))
month = bcdToDec(string.byte(c,6))
year = bcdToDec(string.byte(c,7))
time=string.format(" %s.%s.%s", day, month, year)
print(time);
return nil
function ds3231_m.SetDateTime(wkday, day, month, year, hour, minute, second)
i2c.start(id)
i2c.write(id, 0x00)
i2c.write(id, decToBcd(second))
i2c.write(id, decToBcd(minute))
i2c.write(id, decToBcd(hour))
i2c.write(id, decToBcd(wkday))
i2c.write(id, decToBcd(day))
i2c.write(id, decToBcd(month))
i2c.write(id, decToBcd(year))
i2c.stop(id)
return
return ds3231_m
When I try to use single function calls, it works.
This
m = require "ds3231_m"
m.Init(2,1) --sda, scl = 2, 1
m.PrintTime()
package.loaded.ds3231_m = nilworks as well as
m.PrintDate()
But this (calling three functions)
m.PrintTime()
m.PrintDate()
package.loaded.ds3231_m = nilproduces an error: attempt to call field 'PrintDate' (a nil value)
Can anyone tell me what I did wrong?
Thank you!
