So if you don't touch there, the program is working. The problem is that using the Esplorer AT commands gives the result: "Timeout reached. Command aborted." Using Lua loader, ESP8266 flasher is also unsuccessful - no any respond.
Any idea?
Explore... Chat... Share...
gringo359 wrote:Actually I've found a bug - an addressing at CH_PD pin.
