http://nodemcu.readthedocs.org/en/dev/e ... es/bmp085/
sda on 1, scl on2
My code:
function readBmp(sdaPin, sclPin)
bmp085.init(sdaPin, sclPin)
local t = bmp085.temperature(1)
print(string.format("Temperature: %s.%s degrees C", t / 10, t % 10))
local p = bmp085.pressure(1)
print(string.format("Pressure: %s.%s mbar", p / 100, p % 100))
It always leads to:
Temperature: -13.2 degrees C
Pressure: -306.27 mbar
If I remove the BMP085 Module, its the same.
What am I doing wrong?
Or is this the result if the module is broken?
Could you tell me, how the module should react if nothing is connected to i2c?
Maybe its the default behavier if nothing is connected to answer with these values?
Would be nice if someone could help me.
