New to this forum and starting to play with the ESP8266.
I have bought 4 of those modules:
While starting playing with them, I used the flasher to load the latest firmware but I forgot to pull down GPio0 for flashing on the first 2. One the 3rd one, I did pull down GPio0 to gnd and all is ok, I can communicate with the module and run codes.
On the first 2 modules, every time now after powering up (from x attempts at flashing), the PC (Win10 x64), is seeing the COMx of the board, then gone, then back in an endless loop... while the blue led on the board flashes without stopping.
Those "bad" modules, I can flash alright while the GPio0 is down, I even tried flashing the INTERNAL://BLANK at every offset the flasher worked, but every time I restart the module... I am stuck in this endless loop of connect/disconnect/blue led flash!
If I power up the module after a BLANK flash, I don't see this connect/disconnect issue. But can't do anything with it...
What more can I try?
Thanks
Simon
