Learning LUA at this moment and working with the http server example
-- A simple http server
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
print(payload)
conn:send("<h1> Hello, NodeMcu.</h1>")
end)
end)
Updated by me to get the anonymous receive function replaced with one of my own.
Resulted in the code below :
if srv ~= nil then srv:close() end
conn:on("receive",pr (conn,payload))
end)
function pr(c,pl)
print (pl)
c:send("Hello from updated")
Saved this to "testserver.lua"and run it using dofile("testserver.lua")
But when running I get the following result.
> SENT: dofile("testserver.lua")
> nil
PANIC: unprotected error in call to Lua API (testserver.lus:4: bad argument #2 to 'on' (function or lightfunction expected, got no value))
?!???1?)M?1?)M?1??
NodeMcu 0.9.2 build 20141212 powered by Lua 5.1.4
lua: cannot open init.lua
> Will be because of my limited knowledge of lua yet but
1/ why is my function pr not recognized as function ? (also tried to define function pr before usage but no difference)
2/ what would be the correct syntax to achieve this ?
Kind regards,
Herman
