function Getss()
Config = {}
Config.ssid = "myssid"
Config.channel = 4
wifi.setmode(wifi.STATION)
wifi.sta.getap(Config, function(t)
SigStrength = "No signal"
for k,v in pairs(t) do
if k == "myssid" then
SigStrength = string.sub(v, 3, 5) .. " dbm"
break
print("Signal strength: " .. SigStrength)
end)
Getss()
print("fred")
I would expect an output like this
> dofile("SigStrength.lua");
> Signal strength: -29 dbm
fred
But I get
fred
In the actual code, I want the function to return the signal strength so that it can be inserted into the HTML, but this problem causes an attempt to insert null data into the string.
Any ideas?
