But to run the lua script, does it need to be uploaded every time the module is reset?
Or is it saved and rerun after a reboot
I.e can lua be used for a standalone esp8266 or only one with a Microcontroller attached to upload the script?
Explore... Chat... Share...
print('load LoaLoader')
dofile("LuaLoader.lua")
print('load WifiConnect')
dofile('WifiConnect.lua')
tmr.alarm(1,2000, 1, function()
if wifi.sta.getip()==nil then
print(" Wait for IP --> "..wifi.sta.status())
print("New IP address is "..wifi.sta.getip())
tmr.stop(1)
print('load DS18B20')
dofile('DS18B20.lua')
end)
print('init.lua ready')It takes about 20-25 seconds for home assistant c[…]
