I'm running Arduino IDE 1.6.8 in a Macbook with Mac OSX El Capitan 10.11.6, and a Wemos D1 mini board and I'm getting these errors when trying to upload a basic sketch:
Sketch uses 219,439 bytes (21%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 31,140 bytes (38%) of dynamic memory, leaving 50,780 bytes for local variables. Maximum is 81,920 bytes.
/Users/lean/Library/Arduino15/packages/esp8266/tools/esptool/0.4.8/esptool -vv -cd nodemcu -cb 115200 -cp /dev/cu.wchusbserial1410 -ca 0x00000 -cf /var/folders/yj/d596pq611j3g1xtsr0lxy0480000gn/T/build806b0833718d59be0092c896e1dce655.tmp/Blink.ino.bin
esptool v0.4.8 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.wchusbserial1410
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
opening port /dev/cu.wchusbserial1410 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
setting character timeout 0
done
setting character timeout 1
done
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
This is how my tools config looks like:
When I click upload, I see the serial led in the board blinking for a few seconds, and then I have this error.
I'm new to this board, do I need to connect something? I have nothing connected to the D1 mini board, I have 2 new boards and trying with both I have the same Issue , I've also tried with differents USB cables.
Please help! Thanks!
