Updated 2.4.2 to 2.5.2: blank sketch gives Exit Status 1
Posted: Sat Jun 01, 2019 6:17 am
I've been using 2.4.2 of the ESP8266 board manager stuff for a while now, but finally bit the bullet and upgraded to 2.5.2.
The install appeared to go OK.
I then tried to compile a blank sketch just to make sure the essentials were OK. Unfortunately, I got an Exit Status 1.
An abridged version of the error status from the Arduino IDE follows.
I've seen posts about this error in the past, but nothing seems to have cropped up recently.
Any pointers would be appreciated. If all else fails I skip back to 2.4.2
**LATER** Tried various tweaks, but compiling the core still fails with Exit Status 1. Seems to fail when trying to compile different modules in the esp8266 core. Seems no rhyme nor reason to it, which makes me think might be something more fundamental with my setup. I'll do a fresh install and see if that clears up any weirdness.
Would certainly benefit from any pointers!
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Chris\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Chris\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Chris\Documents\Dev\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10809 -build-path C:\Users\Chris\AppData\Local\Temp\arduino_build_995730 -warnings=all -build-cache C:\Users\Chris\AppData\Local\Temp\arduino_cache_504304 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\Chris\AppData\Local\Temp\untitled772240480.tmp\sketch_jun01a\sketch_jun01a.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Chris\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Chris\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Chris\Documents\Dev\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10809 -build-path C:\Users\Chris\AppData\Local\Temp\arduino_build_995730 -warnings=all -build-cache C:\Users\Chris\AppData\Local\Temp\arduino_cache_504304 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Chris\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\Chris\AppData\Local\Temp\untitled772240480.tmp\sketch_jun01a\sketch_jun01a.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Chris\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2
Using core 'esp8266' from platform in folder: C:\Users\Chris\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2
Detecting libraries used...
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\sketch\\sketch_jun01a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\sketch\\sketch_jun01a.ino.cpp" -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\sketch\\sketch_jun01a.ino.cpp" -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\sketch\\sketch_jun01a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\python\\3.7.2-post1/python" "C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/signing.py" --mode header --publickey "C:\\Users\\Chris\\AppData\\Local\\Temp\\untitled772240480.tmp\\sketch_jun01a/public.key" --out "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core/Updater_Signing.h"
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -g -x assembler-with-cpp -MMD -mlongcalls -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266\\cont.S" -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\core\\cont.S.o"
........ More compilation wibble, no warnings or errors
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266\\umm_malloc\\umm_malloc.cpp" -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\core\\umm_malloc\\umm_malloc.cpp.o"
"C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Chris\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266\\libb64\\cdecode.cpp" -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_995730\\core\\libb64\\cdecode.cpp.o"
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
