Which version (1.6.1 or 1.6.3)?
PostPosted: Mon May 04, 2015 12:26 am
by JohnSL
I'm a little confused as to what combination of tools I should be using. There is 1.6.1 version on GitHub that includes the entire Arduino IDE. Then there is the full 1.6.3 Arduino IDE with the add-in from sandeepmistry. So here are my questions:
  • Which version of the IDE is the best one to use with the ESP8266?
  • Which version of sandeepmisry's plug-in should I be using?
I have some very basic code that uses WiFi.begin to connect to my network. With version 1.6.1 it works perfectly. However, when I run this same code with IDE 1.6.3 and sandeepmistry version 0.0.4, I get the following output, and the status never changes o WL_CONNECTED:
Code: Select allConnecting...
sl
scandone
usl
sul 7 0
..reconnect
rm match
pm close 7 0 0/6080468
scandone
add 0
aid 5
pm open phy_2,type:2 0 0
connected with xxxx, channel 1
dhcp client start...
cnt
Here is the code that works with 1.6.1, but not with 1.6.3:
Code: Select all    Serial.println("Connecting...");
    WiFi.begin(ssid, password);
    // Wait for connection
    Serial.println("");
Thanks,
-- John
Re: Which version (1.6.1 or 1.6.3)?
PostPosted: Mon May 11, 2015 9:20 am
by russmathis
I had to used 1.6.0
then uncheck (if checked) Upload using programmer.
Also had to change the board to uno/compile/then back to the Generic Esp8266
Then the compile worked OK.
This was with sandeepmisry's repo as of May 7 2015.
Good luck
PostPosted: Mon May 11, 2015 11:24 am
by CptanPanic
I have been using the built 1.6.1 from the GitHub readme.
