By Acestu
#30814 Hi, I have been following an installation tutorial from Easyiot and it seems to be out of date because it says select the esptool in programmers menu, I have downloaded the latest Esp8266/arduino software and used board manager to install boards but there is no esptool in the programmer menu, some say you don't need it anymore, if this is the case which programmer do you select ?
Thanks In Advance
Acestu
By AcmeUK
#30841 From your post it looks as though you are using the Adruino IDE with ESP8266 support loaded. I this case just use the Upload button on the toolbar. Works for me :)
