My ESP is this "dev board": http://www.ebay.com/itm/201345364308
My USB to Serial-TTL is: http://www.ebay.com/itm/331529699010 (Pl2303HX based)
My OS is OS X 10.11
Arduino IDE: 1.6.5 (1.6.6 was throwing errors, and I found a post saying that 1.6.5 worked, so I downgraded, and 1.6.5 worked, the one and only time that I was successfully programmed my ESP)
My wiring of the dev board is:
VCC: +3.3VDC
GND: GND from my power supply and GND on the Pl2303HX
TXD: TXD on the Pl2303HX
RXD: RXD on the Pl2303HX
I originally had TXD to RXD, but that wasn't working, so this wiring is what worked for me - once.
I found someone that mapped out this dev board here: http://blog.squix.ch/2015/01/esp8266-te ... eview.html
Basically, I just took the standard blink sketch, updated it so that it would blink pin0 rather than pin13, put the programming jumper in place, powered up the board, and programmed it. It seemed to work, so I removed the programming jumper, and power-cycled it, and it worked! I got excited!
Next, I attempted to update the blink sketch so it would blink faster... I removed power from the dev board, put the programming jumper back in place, powered it up, and tried to program it with the new code... but the Arduino IDE is giving me:
Sketch uses 201,090 bytes (46%) of program storage space. Maximum is 434,160 bytes.
Global variables use 44,608 bytes (54%) of dynamic memory, leaving 37,312 bytes for local variables. Maximum is 81,920 bytes.
Uploading 205232 bytes from /var/folders/1j/02cnzrls7jn85d75wx7vsb6c0000gn/T/build4626231541189908258.tmp/Blink.cpp.bin to flash at 0x00000000
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failedAny ideas what's changed? I do see the blue LED on the ESP itself blink once when I try to program it, so something is happening...
Thanks in advance!
