By atideath
#38904 Hello.
I have a ESP-01 with 1mb flash. How do yo need setup programming? I tried to write flash to ESP more time, but only one start successfully. I can't see anything in serial console. (Arduino IDE 1.6.5)
My Arduino setup is:
Board: Generic ESP8266 Module
Flash Mode: DIO
Flash Frequency: 40mhz
Upload Using: Serial
CPU Frequency: 80 Mhz
Flash Size: 1 Mb (128K SPIFFS)
Reset Method: Ck
Upload Speed: 115200
Port: COM3
The CheckFlashConfig Example is working fine but my code not start. What is wrong? Anybody can help me?
My code is:
Code: Select all/* DHTServer - ESP8266 Webserver with a DHT sensor as an input
   Based on ESP8266Webserver, DHTexample, and BlinkWithoutDelay (thank you)
   Version 1.0  5/3/2014  Version 1.0   Mike Barela for Adafruit Industries
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN  2
const char* ssid     = "xxx";
const char* password = "xxx";
IPAddress ip(192,168,0,13);  //Node static IP
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
ESP8266WebServer server(80);
// Initialize DHT sensor
// NOTE: For working with a faster than ATmega328p 16 MHz Arduino chip, like an ESP8266,
// you need to increase the threshold for cycle counts considered a 1 or 0.
// You can do this by passing a 3rd parameter for this threshold.  It's a bit
// of fiddling to find the right value, but in general the faster the CPU the
// higher the value.  The default for a 16mhz AVR is a value of 6.  For an
// Arduino Due that runs at 84mhz a value of 30 works.
// This is for the ESP8266 processor on ESP-01
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
float humidity, temp_f;  // Values read from sensor
String webString="";     // String to display
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0;        // will store last temp was read
const long interval = 2000;              // interval at which to read sensor
void handle_root() {
  server.send(200, "text/plain", "Hello from the weather esp8266, read from /temp or /humidity");
  delay(100);
void setup(void)
  // You can open the Arduino IDE Serial Monitor window to see what the code is doing
  Serial.begin(115200);  // Serial connection from ESP-01 via 3.3v console cable
  dht.begin();           // initialize temperature sensor
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  WiFi.config(ip, gateway, subnet);
  Serial.print("\n\r \n\rWorking to connect");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println("DHT Weather Reading Server");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", handle_root);
  server.on("/temp", [](){  // if you add this subdirectory to your webserver call, you get text below :)
    gettemperature();       // read sensor
    webString="Temperature: "+String((int)temp_f)+" F";   // Arduino has a hard time with float to string
    server.send(200, "text/plain", webString);            // send to someones browser when asked
  server.on("/humidity", [](){  // if you add this subdirectory to your webserver call, you get text below :)
    webString="Humidity: "+String((int)humidity)+"%";
  server.begin();
void loop(void)
  server.handleClient();
void gettemperature() {
  // Wait at least 2 seconds seconds between measurements.
  // if the difference between the current time and last time you read
  // the sensor is bigger than the interval you set, read the sensor
  // Works better than delay for things happening elsewhere also
  if(currentMillis - previousMillis >= interval) {
    // save the last time you read the sensor
    // Reading temperature for humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
    humidity = dht.readHumidity();          // Read humidity (percent)
    temp_f = dht.readTemperature(true);     // Read temperature as Fahrenheit
    // Check if any reads failed and exit early (to try again).
    if (isnan(humidity) || isnan(temp_f)) {
      return;
By atideath
#38943 I get this error in Serial if my program is run:
Code: Select all ets Jan  8 2013,rst cause:4, boot mode:(3,0)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
Exception (0):
epc1=0x40217fa8 epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000001c depc=0x00000000
ctx: sys
sp: 3ffede70 end: 3fffffb0 offset: 01a0
By WereCatf
#38945 Looks like your code crashes before it even gets a WiFi-connection. Try adding a few debug-statements, like e.g.
Code: Select allSerial.println("Debug");
somewhere, then you can pinpoint at which point it crashes.
By atideath
#38954 I found the problem. The power supply is too low to run ESP8266. So I connected new power supply and It is work fine. Lot of thanks!
