i have an ESP-01, and a sparkfun FT232R breakout board (supports RTS and DTR) and i have it connected up as per http://www.arduinesp.com/getting-started with 2 npn transistors. i also have 2 aa batteries wired in for the right amperage.
im on a mac, with arduino 1.6.5 installed, and have installed the esp boards, and have it selected to generic esp8266.
now when i upload the simple blink sketch i get;
warning: espcomm_sync failed
error: espcomm_open failed
i believe that as i'm on a mac, i should install esptool, or esptool.py (from googling) and have tried to run the install.py (in terminal sudo) but then i get an error saying that it can't find esptool.py...
i feel like i'm missing a minor, but annoyingly needful step.
Sketch uses 198,796 bytes (19%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 33,014 bytes (40%) of dynamic memory, leaving 48,906 bytes for local variables. Maximum is 81,920 bytes.
/Users/kelvinmead2/Library/Arduino15/packages/esp8266/tools/esptool/0.4.6/esptool -vv -cd nodemcu -cb 115200 -cp /dev/cu.usbserial-A601FCG3 -ca 0x00000 -cf /var/folders/xs/fw34443d5pd83bd26mj78qv00000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.bin
esptool v0.4.6 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.usbserial-A601FCG3
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat /var/folders/xs/fw34443d5pd83bd26mj78qv00000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.bin success
opening port /dev/cu.usbserial-A601FCG3 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
setting character timeout 0
done
setting character timeout 1
done
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
done
done
serialport_receive_C0: 00 instead of C0
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
esptool install
Kelvins-MBP:~ kelvinmead2$ sudo python /Users/kelvinmead2/Downloads/esptool-master/setup.py install
Password:
running install
Checking .pth file support in /Library/Python/2.7/site-packages/
/usr/bin/python -E -c pass
TEST PASSED: /Library/Python/2.7/site-packages/ appears to support .pth files
running bdist_egg
running egg_info
creating esptool.egg-info
writing requirements to esptool.egg-info/requires.txt
writing esptool.egg-info/PKG-INFO
writing top-level names to esptool.egg-info/top_level.txt
writing dependency_links to esptool.egg-info/dependency_links.txt
writing manifest file 'esptool.egg-info/SOURCES.txt'
warning: manifest_maker: standard file 'setup.py' not found
reading manifest file 'esptool.egg-info/SOURCES.txt'
installing library code to build/bdist.macosx-10.11-intel/egg
running install_lib
warning: install_lib: 'build/lib' does not exist -- no Python modules to install
creating build
creating build/bdist.macosx-10.11-intel
creating build/bdist.macosx-10.11-intel/egg
creating build/bdist.macosx-10.11-intel/egg/EGG-INFO
installing scripts to build/bdist.macosx-10.11-intel/egg/EGG-INFO/scripts
running install_scripts
running build_scripts
creating build/scripts-2.7
error: file '/Users/kelvinmead2/esptool.py' does not existapologies for the long post.
