For the past few days I have been trying to get my esp chip working without any luck whatsoever, so I decided to post here for help.
What I am currently trying to do is included as something basic in almost every guide online yet for some reason it does not for me. I am trying to communicate with the esp using the serial port (have tried arduino's monitor & coolTerm) and the closest I have gotten so far is this: http://puu.sh/nnjiY/4cc3355214.png. As you can see, I get flooded by "1"s and I am unable to submit any command (for example a simple "AT") as it doesn't listen.
Note that i am using the arduino UNO itself to get serial access (tx/rx pins) to the esp chip and not some USB to TTL converter. I have tried few slightly different pin connections I have found online, yet none of them seems to be working for me (Including both having an external 3.3V source and arduino's 3.3V supply). Here is one of them from electronut: http://electronut.in/images/2014/12/esp8266-circuit.jpg where VCC, Tx, Tx and GND are the corresponding arduino pins.
After some research I have also downgraded to 1.6.5 arduino IDE, have included the .json file in the board manager and have selected the "Generic ESP8266 Module" (don't know If that matters at all during my stage, as I am only trying to communicate serially without uploading any software and coolTerm has the same result as well).
After all these days I either still do something terribly wrong or something is just broken, in any case I am quite desperate for any help I can get from you.
